The LEAP Steel input report for the loads is showing the locations of the field splices in the wrong place. It appears to be 2 decimal places off. The first one in the table should be located at 68.399896, not 6838.9896. Anyone else run into this issue?
I tested this issue in the current release version and i was unable to replicate the issue.
