Does the latest version of OBD have GEOMATH available from within?
GEOMATH/Bridge Parametric Layout module has been deprecated and is not part of OpenBridge Designer > LEAP Bridge Concrete. It was removed in OpenBridge Designer CONNECT Edition, 2021 Release 1 (10.10.00.26). Its functionality are provided through LEAP Bridge Concrete or OpenBridge Modeler.
Release Announcement - OpenBridge Designer (OBD) CONNECT Edition, 2021 Release 1 (July 2021) - LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki - LARS | LEAP | OpenBridge | OpenTunnel | RM - Bentley Communities
The only geometric functionality that I see in LEAP or OBM is very simple alignment creation. The GEOMATH module was much more advanced than alignment creation. It was equivalent to BGS (Bridge Geometry System) and could geometrically define various components of the bridge in much greater detail.
I hope it is brought back in future versions.
Please correct me if I am missing something here...
When starting a new bridge in LEAP Bridge Concrete, you can use ABC wizard from the ribbon and use the "Alignment" option and create the alignment or you could also "Read from Bentley Civil or Import LandXML".
Maybe, there is a misunderstanding here...I am well aware of this ABC wizard to create alignments and components of the bridge. But, the robustness and sophistication of GEOMATH is nowhere to be found in the new versions of OBD/LEAP. for example, using GEOMATH, you could layout out a curved wing wall. However, neither OBM nor LEAP has this functionality.
In OpenBridge Modeler you can model alignments and bridge components. You can create parametric cells and functional components for non-standard bridge components.
