In OBM, I am having trouble re-Annotating a bridge profile. When I use the annotate element under reports and drawings it does not bring back the vertical curve information on the PGL. Has anyone else run into that issue? if so, how do you fix it?
Please email me (dilip.matange@bentley.com) the file to investigate. What version of OBM are you using?
Or you can log a Case and attach the files: communities.bentley.com/.../how-to-log-case
