I am not matching LEAP's operating rating factors for shear (screenshots below) - 0.99 (HL93 Inventory), 1.46 (HL93 Operating), and 0.78 (FL120). I am using the appropriate live load factor for each case. The difference seems to be in the Shear Capacity value used by LEAP as the dead and live loads are consistent between Strength I and Strength II. Does LEAP print the values somewhere that are used in the rating equation? The capacity I use is calculated using the (phi*Vn)/Vu from Print --> Vertical/Horizontal Shear for the governing beam. I did independently verify the moment rating factors and they matched exactly; it is shear I am having trouble with.
Please let me know if you would like the models or the calculation files.
Sathvika, function of POI location and stirrup placement you may miss one stirrup even if the stirrup spacing is constant across failure plane. The method works well if you clearly can intercept more stirrups placed closer than at a given POI.
Thanks, Alex. I ended up verifying the shear ratings for all the beams because for my case, some needed the extra stirrups and for others the multiple shear zones did not apply. I appreciate you looking into this.
Hello, I am still having problems with shear in LEAP. I unchecked the "Consider shear reinf. across failure plane (FDOT Alternative)" under Rating Parameters like suggested. After turning this option off and doing a quick hand calculation to verify the shear rating factors, where I pull the shear capacity, dead loads, and live loads reported by LEAP, the calculated shear rating factors are less than LEAP's.
I am wondering if I should be using a different version?
Can someone please look into this? I can send the models and calculation files, if that will help.
Thank you
