My bridge model has few inverted-T piers. I am trying to "Apply skew to solid" for couple of them, but that doesn't work.
The "Cap Length Adjustment" option does not work either. If I select "Deck and Aligned" option, the pier would change like this (picture below):
I am not able to change the fillet radius of the column to 21" which is what is required. It would change to 20.999", but not 21".
Hi Akash,
I just created a new bridge using inverted Tee in the latest OBM (10.12.1.83) and did not have any issues with all the three above mentioned issues. See images below. If you are using an older version of OBM please upgrade and try again.
Please see release notes for the latest OBM here: NOW Available! OpenBridge Modeler CONNECT Edition 2022 Release 2 - LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki - LARS | LEAP | OpenBridge | OpenTunnel | RM - Bentley Communities
Hello Dilip,
Thanks for your reply. I too have one of the inverted-T bents in my bridge which are skewed but on a straight alignment. Could you try recreating the same bent but placing it on a curved alignment? Like the one I showed in the picture. Also, I'm using the latest version.
Please try creating a new file/model. Assuming you are using the latest released OBM. If that also fails, please email me (dilip.matange@bentlet.com) the file to look at.
Answer Verified By: Akash Chaurasia
Will do Dilip. Thanks.
I tried recreating the model. But have the same issue. I am trying to email you the file but it seems it is too big to share that way. Is there any other way you can take a look at the model?
Please file a case and attach the dataset to the case and we will investigate: How to log Case? - LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki - LARS | LEAP | OpenBridge | OpenTunnel | RM - Bentley Communities
Submitted. Thanks
