My bridge model has few inverted-T piers. I am trying to "Apply skew to solid" for couple of them, but that doesn't work.
The "Cap Length Adjustment" option does not work either. If I select "Deck and Aligned" option, the pier would change like this (picture below):
I am not able to change the fillet radius of the column to 21" which is what is required. It would change to 20.999", but not 21".
Will do Dilip. Thanks.
Hello Dilip,
I tried recreating the model. But have the same issue. I am trying to email you the file but it seems it is too big to share that way. Is there any other way you can take a look at the model?
Please file a case and attach the dataset to the case and we will investigate: How to log Case? - LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki - LARS | LEAP | OpenBridge | OpenTunnel | RM - Bentley Communities
Submitted. Thanks
