In LBC, prestressed girder, the horizontal shear report has all zeros under Avh_rg and they are red. Everything else seems to check out, Avh_provided is greater than Avh_min, and we do have an intentionally roughened girder so I don't even look at Avh_sm. But because the numbers are red, it looks like something doesn't check out. Is there actually an issue that I am missing, or is this just a quirk of the program?
The program is calculating the Avh-rg value based on the highlighted equation .
The Avh-rg values calculated from your file are negative.
When the values are Negative or Less than 0 ( < 0 ) then the program shows 0 value in the output table.
Or if the Avh-rg value is >= 0 then final Positive value or 0 should be shown in the output table
Please check the related Bentley Communities link for more information.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/51273/nomenclature----horizontal-shear
Answer Verified By: Melissa Massar
