Various clients require girders to incorporate hog/camber in 3d modeling. This is something that was traditionally done in Microstation/OpenBuildings and is being done in Revit.
Bridge beams and concrete deck
Is there any way to do this in OBM?
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Mark,
In the next release we will be allowing the user to model beams with camber/hog.
However, these are driven by user input for the haunch values at the ends and the middle of the beam.
Thanks Sri, as mentioned in our emails, we dont use Haunch here and would also request an additional "Thicken Deck to Top of Beam" option to complete this functionality to allow versatility to users.
Added as a comment to the idea here:
Model Camber on Concrete Beams | Bentley OpenCivil Ideas Portal (aha.io)
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
