LEAP RC/PT Girder simple span moment diagram
Hi
I have a skewed simple span 4 T-beam bridge superstructure as below:
I get negative moment at the support locations for the simple span configuration as below:
And when I change the skew to normal (no skew), there are no negative moments at the supports. I am trying to understand the reason behind the difference. Any help would be appreciated. Thanks!
  • Kinal,
    While under CIP module, press F1 key for Online Help.  I did extract below the relevant paragraphs describing the FEM modeling for skewed supports:
    Model Generation
    CIP RC/PT Girder generates a slight variation of a plane frame model for analysis. This is done to account for the effect of skewed supports on the analysis. Skewed supports couple bending moment and torsion in the superstructure and, therefore, the superstructure is modeled using a plane-frame bending element with a torsional degree-of-freedom (DOF). CIP RC/PT Girder automatically calculates the torsional moment of inertia of the superstructure and uses it in the computation of the torsional stiffness coefficient. All transverse displacements are constrained.
    The connection specification in the Bridge Component Layout dialog box defines the type of force release between the superstructure and abutments and piers, or between adjacent span segments at span hinges. The connection is modeled using a zero-length, two-node "super-element" that contains two support-bearing elements spaced transversely along the skew axis of the support. In this way, the superstructure "feels" the presence of the skewed support.
    The stiffness values of the support-bearing elements are assigned appropriate values depending on the specified connection. For example, a pin connection is realized by assigning large values to all translational stiffness terms for the support bearings. The vertical stiffness term for each support-bearing element is always a large value in order to maintain continuity of torsion. In essence, this assumes that the superstructure is wide enough to always transmit torsion into the substructure or across a span hinge.
    The effect of modeling the connection this way is that, when there is a skew angle at a support, an off-diagonal or coupling stiffness term between the bending and torsional diagonal stiffness term is produced. A large skew angle results in a strong coupling between bending and torsion in the superstructure. Box girder bridges have closed, thin-walled cross sections and are torsionally stiff. Therefore, the overall stiffness, i.e., the three-dimensional stiffness, of the substructure is included in the plane-frame model of the bridge.
    This is a test
Reply
  • Kinal,
    Model Generation
    This is a test
