Is this the only location that LEAP Concrete sill show the rotations in the beam? Is it output in a report that I cannot seem to find?
I checked the report and the rotation information is not available.
This is the only place this information is available.
User's should be able to copy and paste the text to Spread sheet or take a screenshot.
Vinay,
Thank you! The entire table can be sent to an excel file or copied and pasted. May I suggest adding a summary of the information based on loading the reports in some fashion? Having the information handy at the bearings would be helpful in bearing design and presenting the information to the client.
Thanks again!
Hi Peter.
You are welcome.
The current process is that the users have to file the enhancement request through the below mentioned Ideas link.If you have a Case number, then please mention so that we can track the Enhancement request.
This is current ideas page for all Bridge and Tunnel Products.
https://communities.bentley.com/products/bridge_design___engineering/i/lars-leap-openbridge-opentunnel-rm-ideas
Vinay
