Hi Guy,
When I trying testing export model tutorial from OBD this software have an error
Please help me to find reason and fix this problem
Log file I attach in this email
Kind regards,
TAlog.txt
Anyone can support me to fix this issue?
Common etiquette remains that you should provide the software version (10.XX.XX...) when presenting an issue to the Community. Could you please present the version of OpenBridge which you are working in?
Best Regards,
Mark
Dear Mark,
I use Open Bridge version 10.12.1.83
Please help me find the solution for this problem
Thank you so much
TA
Please help me to find reason for this problem
Honestly, I do not know why this is occuring. I was actually hoping that someone who is much more knowledgeable about the software might have an answer. Export to IFC should work just fine, but it does not seem to be the case with your model. Have you tried exporting other models out to see if there is a problem with your file/ model (isolated case) or is a universal issue happening every time you try this export? Are you actually exporting out from Pro Stuctures or are you trying to export out the 3D model in situ?
