I am trying to do a load rating for three span steel bridge and the default rating only gives Strength I inventory and operating rating. I added the Service II combination following the steps as in the below link.
LBS - Strength I and Service II Load Rating
When I perform the analysis and rating check, it gives me a rating factor of 999.99 for the Service II combinations I added. Can you please let me know if I am missing any other step or how to fix it?
I am using OBD version 2022 Release 1 - Leap Steel v22.00.02.19
Hi Haressh,
I tested your issue on Tutorial 1 example and these are my findings.
1) I ran the analysis and designed the bridge then saved the bridge.2) Then i Added a Rating and then in the LOADS window i added a new Load combination -- SERVICE II.3) Then applied all the DL and LL and then Ran the analysis.4) Then generated the Rating Report.5) The program was showing the Rating report for flexure for Service II condition.
I was unable to replicate your issue.If you are still facing any issues then please email me the file to "Vinay.Mysore@Bentley.com"Or you can create a new service case and one of the technical support person will look into your issue.
How to log Case.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/52987/how-to-log-case.
Please let me know if you need any additional information.
Thanks & Regards,
Vinay
