LBC 22.00.02.19 [standalone] - analysis results won't reload after saving model
Just want to share an issue that I often come across while trying to open a file that I have previous ran the analysis and also saved.
here is the file size file before running the analysis. size = 208KB
file size before running analysis
after opening and running the analysis in LBC. I hit the SAVE button so that I (in theory) won't need to rerun the analysis again. However, this is not currently happening.
model saved after running analysis
after closing the file, you can see that file size has increased tremendously from 206kb to 6031kb ... which gives the impression that the analysis results were saved.
file size after running analysis
however, after reopening the file. the analysis tab is empty.
is this something Bentley is looking into?
Thank you,
Marcelo
