LEAP Bridge Concrete: Prestressed Box Beam End Block
Hello, I am using LEAP Bridge Concrete CE V21.02.00.38.
I have an end block (solid section of box) for 2' at each end of my prestressed box beams. This will add quite a bit of Vc capacity. Is there a way to incorporate this in the model and take advantage of increased shear capacity?
Thank you for your time.
