Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
LARS | LEAP | OpenBridge | OpenTunnel | RM
LARS | LEAP | OpenBridge | OpenTunnel | RM Forum
Suggestion on Leap RC-Pier
Sign In
Replies
Subscribers
27 subscribers
Views
Users
0 members are here
RC-PIER
Offline
netsonic
over 11 years ago
In Load Tab->Combination, user can let the program automatically create load combinations (load combs)
or user can customize load combs.
But the program auto-generated load combs is very limited, I have to create combs one by one, it's very tedious.
Hope the next version, the load comb auto-generation feature can be improved
When users create their own load combs, the program doesn't allow users to copy and paste the existing combs.
Hope the next version will allow user to copy and paste combs.
In Load Tab, When user edit existing load, or add a new load type from the left box to the right box: "selected", or delete load type,
all the previously created load combs will be deleted automatically by the program, which
drive me mad
Hope the next version will keep the combs even if the user add or deleted load type.
Suggestion:
if user edit load value, keep the combs as they were.
if user add load type, give user two options:
a) keep the existing combs as they were;
b) add the new added load type to all the existing combs, and set the load factor=0.0 or 1.0, cased on user's choice.
if user delete load type, program should delete the corresponding load type in the existing load combs
In load combs definition window, there is a checkbox for "column combination".
If I create 20 combs for all components design, then I HAVE TO create extra 20 combs for just column design, which is very tedious.
I suggest in the next version, the program should add a property besides each load combs: the value should be
1. all the components (this combs for designing of all the components)
2. column only
3. all components but column
By doing so, user don't waste their time to create extra "column combination".
Please escalate the complaints.
