Bug report for RM Bridge
When I want to copy spring from one node to multiple nodes in RM Bridge Modeler,
e.g.
Modeler -> Segment -> segment1 -> select node 1 -> in node 1's connection tab, assuming there is a spring element 101
I want to copy this spring to node 5, 9, 13, 17, I select spring 101 and click "copy spring" button, in the pop-up window,
I put as follows:
From point: 5
To point: 17
Step: 4
Connection Point: CP01
Element: 102
Step: 1
I would expect the result would be:
Node: 1, 5, 9, 13, 17
Element: 101, 102, 103, 104, 105
But RM bridge shows:
Element: 101, 102, 106, 110, 114
