RC-Pier Shear Design Checks
Am I correct in assuming RC-Pier does not check columns for shear capacity?  Why is this?
Also, when checking footings for one-way and two-way shear,  does RC-pier only check Vc?  I'm being told footing stirrups are required, but don't see an option to add them.
  • Hi Mark,
    I agree with you that RCpier program does not check columns for shear capacity . This is one of the limitations of
    the program and will request the development team to add this feature in the program.
    Yes RCpier checks only the one way and 2 way shear capacity and just mentions that additional required footing stirrups .
    Currently there is no option to add the stirrups. The user has to calculate the stirrups separately.
    Please let me know if you need any additional information.
    Thanks ,
    Vinay
    Answer Verified By: Vinay mysore
