I cant check with "UltSup/Rein"
Error messeger " Error: UltChk-Rei: ELEMENT 1001/ 2 -Mz .........."
Can you help me?
TCL file!
https://www.dropbox.com/sh/8heubcqcfb668ui/AAAEU1zOT4PpdZNjReUP6_7da
I have solved that problem. Thank you!
Tung Quach Thanh
Answer Verified By: Tungquach
I copy once more my comments given in your raised Service Ticket I answered already yesterday (also for others to see):
Note that one of the possible hints within the error message is saying that the "number of iteration within QS-Int might be too low".
If you look at the forces for the elements reported (cross-members at bearing axis) there are very small forces, i.e. moments and normal forces which sometimes can cause that the default number of iterations isn't sufficient for finding equilibrium within the iteration procedure.
Therfore go to Recalc Pad / CS-Integration and and set "Iterations" to 10000 which should solve the issue.
In pre-stressed structures note that you also should define the initial strain load case within the actions UltSup Rein and UltSup UltMz.
Thank you, Diether
I have the same problem with error messeger " Number of iterations on CS-integration (RECALC-PAD) too low"
Im trying to change "Iterations" 10000,20000.30000 and more, or "Recurs.level"...but do not work
How can i do?
The number of iterations is only one possible hint if no equilibrium can be found within the Ult-Check.
Check also if you have defined proper reinforcement groups (reference sets of the type "bending" or "longitudinal") in the tension zones of the cross-section.
