We are pleased to announce the commercial release of the following Regional Datasets ( v08.11.09.828) for AECOsim Building Designer V8i, SELECTseries 6 (v08.11.09.829) is now available on Software Fulfillment Center.
These Regional Datasets are available for download in two deployment formats from the Software Fulfillment Center, select the method that best serves your deployment strategy.
There are several schema and dataset changes between AECOsim Building Designer V8i SELECTseries 6 and the SELECTseries 5 datasets. These dataset changes are documented in a dataset “delta” document delivered in the root directory of each regional dataset.
AECOsim Building Designer V8i, SELECTseries 6 can be installed alongside any previous commercially released versions of AECOsim Building Designer, AECOsim Building Designer priority build, or other Bentley application, and should not interfere with the users’ current production environment. Important installation requirements and notices are found in the Readme.
