In the what's new chapter of the help dialog box. I noticed that under the Dynamic View Types section of the book, it shows certain symbols for the Ceiling, Roof, Site and Enlarged Plans. The thing is when we set up the standard project explorer those symbols dont show up? Where or how can I get these to show up correctly?
I do know this works with project explorer - but not fully
When I create a building view be sure to tell it what type you are. I don't think htere are any smarts other than this organization.
I was told this was not ediable but did log this in Jan as if you make a mistake or forget that is a bummer.
And where I saw the power was with project explorer. But I also saw a probmen in that it finds all views and I have a zillion files now listed in PE.
All my sheets have mult sizes in the seed file. Now I must remove all the other sheets or limit the seed file.
Also all my drawings have a "default Model" that does nothing but it does then double all instances of the files in the PE
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
