I'm working (from home) with OBD 10.06.03.04my dataset is on the local machinethe file(s) are on a dropbox synchronized on the machine - so also local
a drawing with a cached dynamic view,from a container-model with about 10 ref (niv 1) each ref has 10 ref ( niv 2) and some hes ref on niv 3 ( about 180 (small - 5- 10 MB) references )
in the DV are about 20 references active (visible)this DV is referenced in a drawing (separate dgn)the drawing, is referenced in a sheet (separate dgn)
opening the sheet makes the DV to recalculate (it is cached.... ? why )
"There is insufficient memory to perform Visible Edge extraction on model: Design Model of file: O:\DOSSIERS\RAFC_F2_T2-4\DESIGN\01_WorkInProgress\01_designs\_ST\03\ABS-A-UV-01-CM-T4-00001-01.dgn. The model will be automatically processed as a series of tiles."
"1 references with more than 2000 entries in the Level Name Dictionary were found.The largest Level Name Dictionary was 3205 entries, in file ABS-A-UV-01-2D-T4-11000-01.dgnPerformance may be significantly improved by compressing RbR_lokaalnummer_11000.dgn and all reference files.Use the 'Compress Options' dialog, with the 'Include References' option, or the 'COMPRESS DESIGN INCLUDEREFS' keyin."
compressing sets back the DV (now some settings are changed)so I can not compress
opening the drawing takes about 25 minutes
machine: HP Z420, 16 GB ram, xeon E5 3.5 GHz, 6cores, 256 SSD hardDrive
How to make the files are loading smoothlywhat about memory usage
what about cached drawing views
Regards Rik
Drawing Views are recalculated on opening maybe because it is set to 'Cached Automatic'. You can try setting it to 'Manual' to avoid this.
You can have a look at this wiki related to drawing view load.
You can also use a batch process to update the drawings automatically. You can find more information on this wiki.
