Are you ready to make the most of your AECOsim Building Designer software and work faster, smarter than ever before? Then the AECOsim Building Designer Special Interest Group virtual workshop on Tuesday, March 20, 2018 is a must-see for you! Register today!
Complimentary, one-hour sessions share the same agenda and are set for at 11 a.m. EDT and 10 p.m. EDT. The focus is Network Configuration Migration to CONNECT Edition and topics will include:
One Professional Development Hour (PDH) will be applied to each attendee’s Bentley Transcript for self-reporting.
See you online!
Are these SIG workshops recorded?
If so, where can we view them ?
Hello MickyKom,
The Success Factors Special Interest Group sessions are recorded. They are posted to the SIG Learning Path on the BENTLEY LEARNserver. This link is to CONNECT Edition sessions: Special Interest Group - AECOSIM Building Designer CONNECT Edition Learning Path
In the LEARNserver there are filters you can apply, to see pre-CONNECT Edition session recordings you can reset the filter and turn off the CONNECT Edition filter.
You can also find these via the CONNECT Advisor. In CONNECT Edition applications you can access CONNECT Advisor in the upper right of the ribbon interface.
I find the best search results to locate SIG sessions is to search for: AECOsim Interest.
Then expand the LEARN category.
The last AECOsim CONNECT SIG posting was December 2017.
