OpenBuildings Station Designer CONNECT Edition, Update 6 (v10.06.03.03) - Release Update
The OpenBuildings product team is pleased to announce the availability of OpenBuildings Station Designer CONNECT Edition, Update 6 (v10.06.03.03) through the Bentley CONNECT Center Software Downloads portal or the desktop CONNECTION Client. Version 10.06.03.03 of OpenBuildings Station Designer CONNECT Edition, Update 6 is a priority maintenance update to the previous released version 10.06.00.40 of OpenBuildings Station Designer CONNECT Edition, Update 6. This is a coordinated release and incorporates the corresponding released updates from OpenBuildings Designer CONNECT Edition, Update 6 (v10.06.03.04) and the PowerPlatform, version 10.13.1.10.
This maintenance release addresses several critical issues identical to those identified with OpenBuildings Designer. The following highlighted issues were resolved; Failing to print to PDF from a DV when sense distance is greater than 1 (1061121), Sense distance is getting hardcoded to 1:0 for placed curtainwall (1062371), Sense distance is getting hardcoded to 1:0 for placed doors/windows (1062371), Sheets not correctly refreshing if the view set to Cached (1061279), and Reference dialog not showing the correct status of the Child References after Incremental CVE update (1063580).
This maintenance release also includes the Technology Preview option to expose the V8i Tasks Interface (1062208). This option is only available for MicroStation V8i Task Interface. The previously delivered AECOsim V8i Task Interface is not compatible with CONNECT Edition due to the consolidation of commands from V8i to CONNECT Edition and the transition from V8i tool settings to CONNECT Edition contextual ribbon bars.
LEGION Model Builder CONNECT Edition, Update 1 (v10.01.01.01) is available as a coordinated companion application with minor fixes.
LEGION Simulator CONNECT Edition, Update 1 (v10.01.01.01) is available as a coordinated companion application with minor fixes.This LEGION Simulator maintenance release also addresses potential access violation when saving res file (1066305).
