Coffee Corner: OpenBuildings Designer – The Next Generation of Structural Elements
Title: Coffee Corner: OpenBuildings Designer – The Next Generation of Structural Elements.
Presenter: Kasia Wlosowicz, Building Application Engineer, Facilities Engineering, Bentley Systems, Michal Sikora, Consultant, Bentley Systems, and Mary Chib, Senior Application Engineer, Bentley Systems
Date and Time: Tuesday, October 19, 2021 at 11:00 am EDT
Register Now!
Discover all the advantages of the new structural elements available in OpenBuildings Designer Update 7 and 8.
This OpenBuildings Designer Coffee Corner will take you step by step through all you need to know about the new structural elements available in Update 7 and 8, including:
  • The advantages of the integration of the new structural elements.
  • New functionality available with the new structural elements.
  • Migrating existing WorkSpaces and WorkSets to the new structural elements.
OpenBuildings Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number.  Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters.  Help
