OpenBuildings Designer CONNECT Edition, Update 10 (v10.10.00.199)
We are providing an update to our most recent posting of OpenBuildings Designer Update 10 (v10.10.00.197) with version 10.10.00.199, which is now available on the Bentley CONNECT Center, Software Downloads portal, or the desktop CONNECTION Client. Version 10.10.00.199 addresses specific issues and localization fixes, therefore if you have already deployed 10.10.00.197, it may not be necessary to redeploy version 10.10.00.199 unless you require one of the following capabilities or experience one of the following issues:
***Please note – If you have OpenBuildings Designer CONNECT Edition 10.10.00.197 currently installed, you will need to uninstall this version from the “Add or Remove programs”, before you install this version of 10.10.00.199. This is necessary in order to update some of the component libraries.
This update will upgrade any previously installed versions of OpenBuildings Designer CONNECT Edition. This 10.10.00.199 re-post does not have any impact on the delivered Update 10 (10.10.00.197) datasets. Datasets prior to Update 10 will require updating.
Important installation requirements and notices are found in the Readme.
This version incorporates several new productivity enhancements and user-requested fixes. It also includes updates from MicroStation CONNECT Edition Update 17.1.
Please refer to the What's New wiki here to learn more.
