Space Label Location
When a space's size/shape is modified, the location of the label for that space is changed. If the label has been placed in a specific location, then it must be moved back to that location every time the space size or shape is modified. Is there a setting that will allow the label to stay where placed instead?
  • Stan - this is the same issue I have been logging with you guys. Losing the user defined placement. Door symbols are worse as titles (for me) have not lost their linkage or placement as often.
    However if you UPDATE your saved view this can tend to cause the titles to reset.
    If there is a log. And based upon CONNECT. I'd rather the room name be placed once as a LABEL AFTER that never moved by the software. I only want it to change or disappear if the section cut does not include that Room. Then and only then would it add a new label.
    Ustn since 1988
    SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64b
    Eric D. Milberger
    Architect + Master Planner + BIM
    Senior  Master Planner NASA - Marshall Space Flight Center
    The Milberger Architectural Group, llc
