How do I create a triangle mesh from height curves in ABD ss5?
Would the Mesh from Contours do what you need?
Sounds so. Where do I find it?
But I remembered - mdl laod facet, facet dialog.
regards / Thomas Voghera
I was referring to the Mesh tools, but the Facet tool you've found should work as well and also does generate a mesh.
It is TOOLS>MESH you talk about?
hm - is it the same tool as Facet? or a new engine?
What is the difference?
Answer Verified By: Steve Cocchi
Yes, see the attached image above.
Regarding the differences between the two... I honestly have no idea! I don't really work with our Mesh tools that often to know whether it's different code or just UI.
