I have placed many interior elevation callouts in a plan view, then created drawing models in a new file, which were then linked by dragging into a sheet model in the same file. The callouts report properly at first, using the numbers assigned by AECO.
However, when I edit the Identifier (in properties) to conform with our system, ("2" becomes, say, "24.1 N") callouts do not update. I think they have in the past, but not now. I have tried the update tags icon in Annotations, and I have tried the Update Automatic Annotations in Drawing Compostion, to no effect.
Advice?
When I place the Title - the bubble and name are great. The number starts with 1 and continues as I go on this sheet and the title is the model name.
However when I select the title and change the name it does not reflect in the Model nor any other instances of the placement of that item
Same for the Detail Number. If I change 1 to a D1 it does not change the property somewhere to D1.
The Scale if Great and the Sheet Number is Fine.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
