Since we use AECOsimSS5 (08.11.09.747), we have an issue with Building View Attributes.
When I activate BV Attributes (I do not change the Display Style!) the display/appearance of Mechanical Components changes.
The Components look like in a Visible Edges Render Mode.
It changes only Mechanical Components. Ohter elements ( Architectural, Structural, other Solids) do not change it's diplay/appearance.
Building View OFF Building View ON
SR 7000238513 filed.
Does anybody have an idea what is wrong?
Thanks.
Christian Mittermeier
Yes, an example would probably be best. Your screen captures are showing that building attributes are being applied to the view, therefore Family/Part resymbolization + Display Style overrides would (or could) take place.
OK. Here is an example (reduced file size) of my file.
And here is my file of the Dataset Explorer settings.
I would suggest logging an SR with support for this. I've looked through your file and while I do see the behavior I haven't found any obvious cause, other than (I think) a connection to Display Styles. For example, by disabling the visible edge color override the black edges revert to their normal colors... though when not demoted this isn't necessary. Hmmm....
Steve, Thanks for your answer. SR 7000238513 is already filed.
Yesterday I tested the same example file with AECOsim SS4 with the same Dataset settings.
This issue do not happen with SS4.
