AECOsim BD Roof Builder - Holes
AECOsim BD SS5 08.11.09.747
Is there a way to cut holes in roofs created with the Roof Builder tool (morph forms)?  I can't seem to figure it out with the traditional cut tools, penetrations, or new roof editing functions.  If you search AECOsim BD Help for "The Roof Building Utility", it states that "Creating holes in a roof" is one of the many modification operations when the Modify Roof tool is used.  All I can see is this tool edits the DataGroup Data.
TIA
  • Mark: penetrations do work, but you'll need to crank up the sense distance in the DG dialog.  Also, I have found ( and have put in a SR) that the roof element only supports one single penetration.  That isn't too helpful to me...
    Shawn
  • Try these tools (from another forum that we're not supposed to link to):
    "Cut Solid by Curves proves vital far too often in 'old' ABD because of the unco-operative deficiencies, fussiness and weird results of the main ABD modification tools.
    So also does Subtract Solids get heavily resorted to; and so also would Trim Solids and especially the Push-Pull tool, if these weren't arbitrarily (lazily, it seems) deemed illegal on BD Solids.
    Continually using these MS tools alongside BD tools, leads me to seek removal of the lazy demarcations between BD and MS, between Forms and Solids, between MS tools that work in BD and the ones that inexplicably don't.
    Also adding to this desire to unify, is the arbitrary way that some ABD tools result in BD history-based Features and some don't; the cumbersome way of accessing BD Features; that BD Features appear to be quite different from 'new' MS Features, which are different again from 'old' MS Features (which were advertised as being abandoned - but they still seem to be here)."
  • Thanks Guys.
    @Shawn, I tried penetrations both with our workspace and out of the box and I could not get them to work.  The message center even states the "Element is not valid for tool". I did a bit more testing and found that the Construct Opening tool does work (Form Modeling Task Tab > Last tool in Manipulate Features).  It also allows multiple openings.  For novice users I would suggest reading the help as there are few accept/reset steps involved with selecting the opening and form.
    @fostertom, I tried most of the tools you mentioned first.  The Construct Opening tool was the last one I was going to try.
    Thanks again.
    Mark Mates - BIM Manager - Mason & Hanger
    Answer Verified By: mmates
  • @Mark, here's the image of what I did with a roof element and a penetration.  You can check the DGN file attached as well.  HTH,
    Shawn
    roof.dgn
  • @Shawn, Thanks for the response. I haven't had a chance to try it again. I did see your method work for another designer in my office. In the end, I found the Construct Opening tool to be very easy to work with. You just don't get any data like you would with the User Defined/Penetration method.
