ABD SS5 - 08.11.09.747Drawing Extractions - Generate Centerlines
Has anyone ever seen a mix up with centerline linestyles upon extracting a file? The image below shows an example of our firewall linestyles. One diamond represents a 1HR wall and two diamonds represents a 2HR wall.
If I start a new file, they extract fine. On one problem file, when extracting the plan with generate centerlines in the cut plane tab, the linetypes are reversed - one diamond for 2HR and two diamonds for 1HR. All I can think of that is different is I changed the family/part settings after the walls were created in the file. I tried reapplying the part settings and the information shows everything is fine. However, the extration result does not.
Mark Mates - BIM Manager - Mason & Hanger
Mmates, have you try using Drawing Views instead of Drawing Extractions?
Unknown said: Mmates, have you try using Drawing Views instead of Drawing Extractions?
Yes, they are not working for us and I'll post in a separate discussion the reasons why.
