We are pretty much following this workflow:
We have several „container“ files with drawing models and sheets and a group of people is working on these files separately. When creating new callouts in the container files we get this message and are not able to create new views/drawing models, as far as I can understand, because the " first one“ takes ownership over the composition filel where the views are stored.
Below is the message we get if somone else has taken over
This reminds of „Activate“ command but with that one you just deactivate and the file is open for others to work on. It is not the case here and we only get the message:
Is there an option to "unock" the compsition file?
Can this be solved by any setting…. or config variable?
AECOSIM/Microstation is known for its functionality in group working….I do not understand how this can function in a work group…or am I misunderstanding??
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
