Please show me I'm wrong, before I abandon ABD and go back to 2D Acad!
296D complete.dgn shows the kind of existing house (dark grey) and 1st Fl (2nd Fl. in American) extension and Loft conversion (colour).
Next, 296D previous.dgn shows same stripped to show the kind of Form shaping and joining required - has been tricky in ABD all the way, to keep all as ABD Forms i.e. not using any of those MS tools which result in Form demotion to SmartSolid. See particularly the complex shaping at the apex - would anyone say that with practice this kind of modeling in ABD becomes quick and straightforward?
Next, 296D altered.dgn shows how I want to alter the detail at the apex. It's excellently easy in ABD to rotate the untrimmed sandwich of Forms into the revised orientation - but how then to extend, trim, join them, and other Forms already placed, to each other? Remembering how, even after months of 'getting to know' ABD and all its funny little ways, it was such a struggle to 'fool' the system into making the shapes and joins in 296D previous.dgn, I simply can't face going through that again, to make this simple (though geometrically complex) alteration. Especially knowing that the next bit that I tackle will be just as tricky.
It's not just about making this particular alteration - that's just an illustration of the inability of ABD to handle doubly-rotated planes, other than rudimentarily simple cuboid geometry. That is my conclusion, after months of intensive trying to find routines that work, beyond the documented and intended cuboid. I imagined that ABD could be nudged to make practically any angled/intersected shapes, with a bit of experience. As far as I can see, that turns out to be far from true.
Please show me how I'm wrong about that!
Because, as far as I can see, ABD is not working for the kind of Architecture that I do. And I doubt that Revit, Archicad or the others (please don't say SketchUp) would do much better, or even as well.
Therefore I have returned to doing this and future project in old familiar 2D Acad 2006 (which doesn't even have 3D to speak of).
I can readily do it in 2D - see my post of 2014-10-22 in https://communities.bentley.com/products/microstation/f/273/t/101988 . But it is arduous, manually keeping plans, sections, elevations consistent together, and the 3D trigonometry, to draw doubly-rotated objects in elevation etc, does my head in. All the well known advantages of creating a 3D model, with automatic view-planes.
I naively thought that AECOsim, the industrial-strength 3D building application, would automate it all, like no other. Right now I am disappointed and disillusioned, to put it mildly, and massively out of pocket.
Hopefully I'm just missing some understanding or practice?
Perhaps lucky that there is now hope of radical improvement in ABD's geometry creation and modification over the coming year and a bit, for the first time in 19 years of absolute zero UI development since Bentley bought Belgian mdl ap BricsWork in 1995 and re-named it Triforma.
regards / Thomas Voghera
Thanks Thomas - I think you know ABD like no other (when did you start?)
Unknown said:simple (though geometrically complex) .... you said it
Unknown said:it will be tricky to model in ABD
Unknown said:And not so easy for a carpenter as well
Unknown said:Cut Solid by Curves, modify and connect form tools will do what you show. It will be easier if you allow boolean tools also.
to fill in for the inadequacies of ABD's modify and connect form tools. ABD tools as first preference, MS ones where ABD tools refuse or send Forms shooting off to some remote intersection etc.
Yes I can work around all these tools, but with so much failing - I lie awake figuring out the approach I'll try tomorrow. Always I retain the Forms as Forms, not using those MS tools that result in demotion to SmartSolid, because Forms' behaviour is always more suitable for further modification. But after multiple MS operations, although still reporting as a Form, ABD operations cease to work on it.
Believe me, after months of trying everything, it's true that "Cut Solid by Curves, modify and connect form tools [boolean tools also] will do what you show" - but at completely unacceptable cost in abortive work, frustration and time, and way beyond the programmers' concepts and intentions.
Anyone got any more ideas?
Thomas, if important, could you say more about how ACS and RE come into it, what I should be asking Brien Bastings about, and also Demotion?
Unknown said:what do you want to achieve? In what stage of the project? Drawings? It will do. Quantification - much harder. Illustrations for client?
Unknown said:Easy modification like Implied Relations
Unknown said:3d-modeling is nice - but it also forces you to resolve all joints and meetings everywhere in a building
Unknown said:2d is very economical
Today’s ABD is so far from adequate, but so close to being magnificent, over the coming year. We hope!
Yes - I see that also.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Would we agree that no.1 on wishlist is Connect tools that work on all Form faces equally?
ABD's cuboid concept assumes that the only faces that need a L- T- or X-Connect, are Ends - so only pairs of Ends can trim/extend to each other. 'Trim/extend to each other' is the key thing, the key to a competent Building modeler - but it's cripplingly limited in ABD, allowing End-to-End only. That does work beautifully; it even allows lap-priority. Connect Form is the prime ABD modification tool, the fastest, simplest and most reliable.
The second-choice ABD modification tool is Modify Form, lacking any 'Trim/extend to each other' ability. In Modify Form, only Top and Bottom faces (not End faces) can Trim/Extend directly to another Form, but without affecting the other Form - exact same effect as the T-option in Connect gives on Ends. Modify Form is slow, tricky, internally inconsistent and often unpredictable in result.
Just imagine - if all Form faces - Top Bottom and Ends - would work equally, then L- T- or X-Connect and Modify>To Form would merge together into one easy Connect tool. Optional multi-select as well as single-select would allow optional multi-facet as well as single-facet result.
Just that, would turn ABD into a geometrically competent Building modeler, free of its dumb cuboid limitation. For a start - of course there's more.
Side faces alone would disallow multi-facet result: a Form is hardly a Form if not parallel in thickness.
Though you'd like it Eric
To be clear, Connect tools that work on all Form faces equally means not just Top to Top and Bottom to Bottom, but all combinations equally - Top to End, Bottom to Top etc as well. An end to trying to keep track of which is Top, Bottom, End etc. For the great bulk of routine work, which really is strictly cuboid and ABD handles so productively, nothing need change.
If that's all that Bentley's mainstream big corporate Architect customers demand of ABD - utilitarian automation of routine cuboid commercial building production, and of the boring routine bits of their more ambitious buildings, then that's because those corporates have other Building modeler software to do the more imaginative bits that make a 'signature' building. That superior Building modeler software is their highly expensive investment, and its capabilities are guarded as their competitive advantage.
Cos like Fosters have long had their own sophisticated in-house mdl aps, which can do sophisticated geometry (BricsWork (Belgium, 1993) started as one such mdl ap, which Bentley bought and re-named Triforma, but never developed beyond its cuboid capability). Others have paid megabucks for Gehry Technology's Catia based Digital Project, and now Dassault are directly introducing Catia Building modules. Jon Hirschtick’s Belmont may be following close behind. Rhino and Bentley GC are in the mix too. These softwares specialise in NC-manufactured curviness that only the big boys have the key to.
The result of this software stratification is our cities today – a zoo of all the limited tricks that Revit can do. If it can’t be done quickly and profitably in Revit, it won’t happen. Blocky buildings compete by façade variation, with stuck-on features and eye-catching roofs.
Low grade commercial buildings have always been like that, but until the 80s very many quality Architects loved to find new geometric/spacial solutions in response to social, technical and townscape needs. I feel so sorry for new Architects, with nothing between Revit façade-wallpapering on one the hand, and for the elite, Rhino exhibitionism on the other hand.
There is no 3D CAD-supported middle ground, for good provincial Architects to return to designing radical buildings, creating new freer geometric/spacial solutions in response to social, technical and townscape needs, and detailing them for buildability by ordinary builders, out of common materials.
ABD does not support that – it’s typical of what has been lost to commoditisation, ever since the Reagan/Thatcher years.
The answer is as simple as ABD Connect tools that work on all Form faces equally - that's all it would take to turn ABD into a geometrically competent Building modeler, free of its dumb cuboid limitation. For a start - of course there's more.
