I was making a more complex model (hollow core slabs) where I noticed the problem. So I tried it in a new model with basic solids, to see if that problem also appeared. Here is the setup:
I have a simple slab solid. I attached a part to it. I also have 2 slab solids, one at the edge and one in the middle of the big one. You can see the setup with a clipping applied to it (image 1).
When subtracting the solid at the edge, it seems perfect (image 2), but when subtracting the one in the middle the solid doesn't seem solid anymore (image 3).
I also noticed when using the clip volume in other directions (plan view or parallel to side view) the section is ok, when using the parallel to front view clipping (which is the direction you see above) the problem accurs. It looks like the front view settings are ok, just the cut view settings don't seem to work?
Hi Steve,
I tried to do the same with the cut solid by curves. But I got the same result: when cutting a hole at the edge everything is ok, but when it's in the middle of the solid it results in the 3rd image in my 1st post.
I 'solved' it by making 2 shapes with a hole at the edge (image 1), putting these 2 solids together and using a unifng part:
Still I'm wondering if this is just me or do others notice the same problem?
Windows 10 pro
OpenBuildings Designer Connect Edition Update 8 -version 10.08.00.44
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Eric, Steve,
here is the file:
for-file.dgn
