Any idea where the steeldeck properties are defined?
Hi Rik,
I'm using the Structural Property Catalog Management application. However, it is simply a viewer for the associated section databases so not editable. If you want to know more please file a SR with support since it is an undocumented and unsupported tool.
from the help files:" Note: Usage of Bentley Structure Property Catalog Client library is restricted to Bentley internal and authorized users only. "
so we can't use it?
Marc Thomas said:forthcoming integration of ProStructures functionality
Sorry for hijacking this, but I'm intrigued. What sort of integration are we talking about?
Basically... yes. It was not designed to be a user-based tool. Unfortunately I don't know much beyond that.
I'll leave the details to the official announcement, but at a basic level imagine placing and modifying native ProStructures beams and columns, pulled from the ProStructures section database. Including custom sections. There's more to it than that by far, but since you asked...
