BBES The current design file is not an electrical design file
Hi
       I have just installed AECOsim SS5 to evaluate. I have launched aecosim electrical, created a new file from default seed file.
When I go to use any of electrical design tools the message centre displays the following text.
scrolling down in message centre also contains error.
TFBXS_SEEDFILE:C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i Ss5\WorkSpace\BuildingDatasets\Dataset_US\seed\DEM_templates\DEM_Templates_Electrical.dgn
  • well - clicking the bbes.reg did work - so I get something working.
    But the raceway was strange.
    regards / Thomas Voghera
  • As Steve mentioned, make sure the Raceway dialog box hadn't just moved behind the other applications. The ABD Electrical dialog boxes are modal, meaning when they have the focus the other tools are unavailable until you dismiss the electrical dialog box. Looks like you have a that worked out Thomas.
    Some of the electrical dialog boxes will have a ">CAD" button that will temporarily dismiss the electrical modal dialog box and allow you to use the view controls for example, a right-click takes you back to the electrical dialog box. Some electrical dialog boxes will have a "Select" button that will temporarily dismiss the electrical dialog box and you are picking a point in the model
    (to define the height of the symbol for example).
    On the Raceway placement - the raceway will attache itself to the last placed raceway component. You'll see a green triangle in the view, which indicates where the new segment is placed. There is a "Select Connection" button that allows you to set that triangle connection point to a different location (after you have a raceway model in progress there may be several points to choose from). The "Select Connection" button temporarily suspends the Raceway tool like the ">CAD" and "Select" buttons.
    Taking the opportunity to disseminate some ABD Electrical information!
    Thanks!
