Running AECOsim Building Designer SELECTseries 5 (08.11.09.747)
New Joist Tool vs. the Old Bar Joist Modeling Tool
So the options are use the old Bar Joist Modeling tool and drop the joist, or use the new Joist Tool and add the joist seat at the detail level. Am I doing something wrong with the new tool, or is this accurate to what you have seen?
This is also our experience with the new bar joist tool. We have as you know left the old bar joist tool in for our users by way of the key-in. so having said that, it is our hope that using the new bar joist tool in tandem with the old tool, will give you the desired effect.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
@ Eric M. - Agreed you have to pick one or the other. And so far I have always picked the old one, I find the newer tool to be useless. @ Jeff - Tool --> Toolboxes --> STR Utilities. It is the 5th icon.
