Hi all
When using File > Import > IFC, with Ignore Storey Containment unticked, the DGN files created do not seem to use the correct seed file. Either that or the import process ignores the global origin and imports the IFC into "true" space. i.e. the IFC model imports many km outside of the SWA, despite the coordinate system being set correctly.
Does anyone see similar problems, and does anyone have a fix?
Hi Nigel, when I round-trip an IFC with Ignore Storey Containment unchecked, the coordinates I see when tentative snapping on the imported results are the same as I get when viewing in Solibri. How are you checking the IFC in its native state?
