I can see that door architraves parameter can be hidden in edit catalogs, but it appears this only means the parameter is hidden when modifying a door.
what I want is a door with no architrave at all, ie external doors do not usually have an architrave and some internal doors have a different architrave profile that the one that is loaded when inserting a door.
Hello Richard,
Yes, it is possible to "hide" the architrave by giving it a value of 0:0. This can be done by going to Modify Door (right-click on door to be changed and select Modify Door), in the Modify Door dialog box put a check mark beside Dimension | Frame Return Depth and change the value to 0:0
HTH
Answer Verified By: Steve Cocchi
This is all correct, but if you do this to "hide" the architrave, it breaks other parts of the parametrics. It's clear to see if you place a simple door:
Answer Verified By: richard kettleborough
