Dear Bentley,
Kindly assist how we go about that the architectural elements such as brickwall,plaster and etc could be auto deduct/ trim when they meet/interface with the structural elements such as beam,slab,column and etc.
regards,
Conny Chang
They would not trim to those elements. They could Unify to those, but even then typically you would have an expansion or construction joint like where a oclumn meets a floor of the same material. Now you can use tools like extend wall and that would happen. But there is not a way (liek the "T" Wall Tool) for a wall to be "T'd" into a structural element.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
