I am in a drawing that I have placed a reference that places a drawing Title
I want to edit the look of that cell
I go to the annotation tools and it open a cell library with teh file I want to edit
I make changes
then open and place a drawing
Teh cell is the same old cell without a change.
Even though the utility takes me to a cell library it is the wrong version.
any help is appreciated.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Eric,
There are actually two locations for drawing titles.
If you are accessing it as you describe, it is taking you to annotation cells that are used to populate
Previous V8i annotation tools. See Image
To access new drawing title cells that are attached to reference files.
you need to look where configuration variable MS_DETAILINGSYMBOLS_CELLLIST is pointed.
These are cells that are used in conjunction with Detailing Symbol Styles and Dynamic Views.
Ok but mine is not this issue.
I have the variable set as you can see -
This Variable points to my personal Detail Dgnlib.You can see that the variable is received properly.
But when a detail is placed it is placing the Bentley Detail
What I ahve to do is delete teh Bentley Detail as a path is hard coded somewhere so that I can only update one in my dgnlib.I'll log that one in a minue.
The next question is can I void the Symbology like on linestyle as I want more createive bubbles that flat one weight. or style.
Now I have gone to the Detailing Symbol Styles dialog
I added A Drawing Title and several things are unclear.
