I am puzzled and don't know how to solve this. I know this can be a bit tricky as it seems like a localised problem, but if anybody could help that would be a huge help.
I will try to explain
My work space is directed to a common location for the whole office users. We have not yet started doing projects in AECOsim but we intend to start in the near future.
While started working on AECOsim I have noticed that my floor manager is not working as it should be. It is not placing elements at the selected floor. I have asked one of my colleagues to try and he also had the same problem. A third colleague who's work space was still directed to the C drive had no issue at all. So it only affected two of us who used the workspace created for projects. Then by following the previous discussions here I figured out that there is a problem with the seed model of the project created for company users. Configuration was different to dgnlib. So my other colleague(who had the same problem) tried with a different seed file copied from GBdataset and it worked fine for him. I tried the same trick but it is not working for me and I don't know why? Even the file working fine for him when opened in my machine is not doing. There may be some wrong setting in my C drive but I don't know where to look. Help me please.
Boney
What is different from your system and theirs. Is it just the dataset? If so save a copy of yours and start with a copy of their's and just copy folder by folder yours onto there. And see where this woud lead to. Try the dgnlib first then so on..
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
