I`m using AECOsim Building Designer V8i (SELECT series 5) and I`m having some issues when using Bentley driver to print my PDF.
I have established a Plotsetup with the line/Print width I need but the result is not as expecting. The line quality is poor and gets even worst when zooming out 200% 300% and so on.no difference if I Can somebody help me? Is this a Bentley issue or an Adobe issue? And what can I do to get a good quality PDF that scales correctly
Mauro
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Mauro, Edit the pdf.pltcfg printer driver configuration file and set Precision to Maximum (see .jpg below). Save and Reload the printer driver configuration file and try your print again.
Let me know if this does not help.
Larry
Answer Verified By: Steve Cocchi
Marc
