Dear Bentley,
Kindly assist how to union the surface area for 2 solid instead of their volume?
regards,
Conny
Ah... I see. Yes, what you are describing is correct. The reason you are seeing this difference is that when any type of Boolean operation is performed on a Form, whether a Union, Cut Solid, etc., that operation generates a Feature on that Form (first selected for a Union). With a cut the result is fairly straightforward since material is being removed from a single entity, but when performing a Union you are essentially adding the mass of two individual objects. So what you should see are the Areas and Volumes for both the combined Forms listed in the Building Info > Quantities tab.
There isn't a single total shown for Area like there is for Volume, but I think this has always been the case.
Answer Verified By: Steve Cocchi
