Good day. I am using AECOsim SS5 and i am trying to do an export to Cobie but no success. I did all the instructions from the USER GUIDE i downloaded. Unfortunately the IFC exported has no element and excel says invalid file format. Any Ideas?
Thanks in advance,
Vince
Hi Vince, Is IFC_PROJECT set to = 2 in the PCF? Were any elements selected when you exported? The IFC translation module will export either the whole file or a active selection. Note that COBie is a subset of IFC that will only include maintainable items.
Marc
Hi Marc
ABD SS6 GB dataset
I have just came across this error. I have the IFC_PROJECT =2 set. When we export IFC and include the option to create the COBie spreadsheet we get the following message (see image)
I used the whole file to export.
any ideas........
Thank you
Hi Ian,
It looks like the Excel file is not quite intact... There were no error messages during the process?
Did you reach any solution regarding this error? As I am currently facing it.
