Dear Bentley,
Kindly assist us which curtain wall tool to be used to develop the curve/round curtain wall on the top view from elevation as per attached image:
regards,
Conny
Hello Conny, There are no delivered round or arched top curtainwalls delivered with AECOsim, but you could create one using the tools in PC Studio as per the PC Studio Reference Guide: R - Radius: Create an arc segment by specifying the radius of the arc. This option creates an arc that is defined by the direction of the chord between the vertices at its start and end points, and the radius is derived from a combination of the length of the chord and the included angle of the arc. This provides a more convenient dimension inference for editing. During creation, the left/right arrow keys ï ð are used to adjust the arc's included angle to the desired value. The value of the angle will step up or down by the current Angle Snap value.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
