Good morning,
I have a quick question. I have created a compound wall, the one on the far right. Nothing special, internal finish-external wall-grc panel.
We have 20mm gap between the external grc panels. In the model, the windows penetrate the wall however when we export to IFC, some of the windows are not there.
I have attached images of how it looks. Any suggestions? And no, the windows are not the wrong way :)
Image1: AECOsim
Image2:BIM Vision export (front view)
Image3: Bim Vision export ( inside view)
Image4: Compound wall settings
Hello Nasir,
Thank you for getting back to me. Yes, I have tried using Solibri too and it was the same result.
Please see file attached. Hope it works ;)
m_CL_test.zip
I have tried to do some experiments with various different walls and this is the result. The only wall in which the windows can't be seen is the one on the far right.
As mentioned, its not a complex wall type.....
Answer Verified By: Steve Cocchi
