I am using Modify Structural Attributes to change the length of a concrete column. When I apply the new length value, I get the message "1 element changed" but the length has not been changed... Any ideas?
OK so you are saying the "Structural Quantities" in the "Modify Structural Attributes" dialog are not meant to be edited... OK.
Yes I do realize you can modify the column in a number of ways, the reason I was asking is what happens when I have to modify a large number of columns in one hit? Why can't we use the Modify Instance Data tool just as we do for walls - select a whole bunch and change the height, the end... Am I missing something?
Chris, Have you tried this with SS6?
