Part Centerline - wrong orientation - solves centerline patterning
I think I may have solved the centerline patterning.   It is working right now but in the wrong direction.  the orientation of a centerline used to be right to left.  it is right to left on the dialog box but when patterning the secton it is up and down.  the "Width" of the part is left to right so how come the centerline is running up and down???
Here are two examples of centerlines that are going in the wrong direction.
One:  This is "X" for rouch carpentry.  Most all is 1/1/2" for where I use it alot so I can create one pattern at 1" that by default will work with all 1 1/2" stock if I scale to 1.5 and pattern to width.  This is currently working but matching height and not width.
The second is for rebar.  I have lines stryles to cove most combinations of rebar in a slab or footing, from one to 3 layers
It is not placing like it used to.  there is no stretching on this one as it is full length of slab or footing.  but notice it is placing in the wrong direction
