Interesting comment from http://www.archdaily.com/302490/a-brief-history-of-bim/ :
"[BIM] ...workflow is based on the existing building stock and common industry standards and therefore a project which is produced in a BIM platform which emphasizes these tools is likely to reinforce existing paradigms rather than develop new ones. Additionally, the programmers who worked on the early BIM platforms often did not have a background in architecture but employed hybrid architect/programmers who contributed to the development of the programs ... The roots of the major BIM platforms that are in use today have been developed by programmers with the peripheral input of hybrid programmer/architects and a global user base who contributes to the development of the software via ‘wish lists’ or online forums where grievances can be aired about a product workflow. The grievances typically result in new features and build upon the existing interface."
In other words, even now, whichever of the competing BIM companies has the courage to dump its introverted dogmas and goes out to seriously understand the strange needs of real practicing architects, structural engineers, electrical and mechanical designers etc, will steal a big advantage from its rivals. I hope that can be Bentley.
Problem is, that the BIM companies trully believe they are already doing that. They consult extensively with their most important corporate designer customers and do their best to satisfy the corporates' wishlists. The BIM companies do not realise how unrepresentative those big corporates are, of the broad design industry.
The big corporates have very specialised production-line routines which generate very specialised wish lists and hence BIM tools which seem seriously unreal, missing the mark, to most designers.
Also the big corporates have other expensive tools such as Gehry Technologies provides, to do the 'interesting' parts of their 'imteresting' buildings. They only need the likes of AECOsim to do the routine, production line bits of their 'interesting' buildings, and to do the whole of their most mundane buildings.
The BIM companies do not realise that their products are only valued, by the big corporates, for their most boring buildfings, and the boring bits of their 'interesting' buildings. However, it's true that the BIM companies' products are ideal for the most commercial, productionised, cheap to design but valuable to sell/rent, profitable bits of the building industry's output.
Who's to say that's wrong? That hard-nosed profitabile sector may be the deliberate target area for e.g. Bentley - maybe Bentley isn't interested in serving the complexities of more 'interesting' buildings, which are demanding to design and document but not necessarily proportionately valuable to sell/rent.
I doubt there will ever be a public clarification on that question, so I for one await to see just where the development effort goes, as BD goes 'Connect' -
will the relatively small steps be taken (it's so close!) to enable the 'do-anything' creation and modification of geometry for 'interesting' building mofdeling without unsatisfactory resorting to MS -
or in Dominic telling phrase in https://communities.bentley.com/products/betas/aecosim_building_designer_selectseries_6_eap/f/343506/p/107078/326739#326739 , will priority continue with tools "that allow the 80% most common cases to be done with ease/no thinking/customization"
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
KB:
"You could have the smartest technology with the coolest demo of the newest solution but if people say ‘that’s not the way I work and I’m not prepared to change the way I work” then you are wasting your time."
"The future happens to us rather than by us. There is no masterplan for the road map for the next 30 years. Every five years we look back and ask what is different today. The decisions we made five years ago were all based on the technology available and the problems that we wanted to address. Sometimes the right decisions of the time turn into the wrong ones for all sorts of reasons and so you have to keep revising the plan."
There will always be a mismatch between how people work and the lead-in time required to introduce and implement the tools that enable those workflows.
It's important to bear in mind that how people are prepared to work is also symbiotic with the tools that are available + a learning curve + eco-system. If you provide the tools and environment, workflows will change. I suppose that the published example of this is the way DS tries to market CATIA/Enovia etc. They sell a whole eco-system and tell the client that this will require change in work practices 're-engineering' style.
It's not always about asking users what they want. Most times they are backward looking and won't know what the future will be in 5 or 30 years etc.
Maybe its about identifying the 'timeless' or 'profound' functionality like speed, scalability, reliability, UX, longevity, compatibility, adaptability, composability, interoperability etc and focusing on that. It seems like a lot the problems are really to do with lack of follow through and 'profoundness' over time. Functionality that is brittle and perishable over time.
developing for Mstn... circa 2000.
Unknown said:The coders need to produce tools that they themselves find cool and powerful to use.
For me, the 'developing' link produces an empty pdf?
Yea... and that was with JMDL (would have been replaced by dotNET) which is a managed language which shields the coder from all that resource management that compiled languages like C++ etc require. It also only about the 'upper level' UI interactions, and not all that 3d solids modeling kernel coding or the parametrics change management etc that will be needed for all that nice TF joins etc that we have been discussing. All of which would need to be coded using libraries provided by others, which are apparently are often 'take it or leave it'... or yea we know its a bug and its on our backlog for years (sound familiar?) And that's if the library publishers are still around and cooperating.
A more detailed version of the report below:-
That sounds alarming - surely Bentley have faced all that (whatever it means) recently during the ground-up (?) rebuild of MS, which must have gone deep into '3d solids modeling kernel coding or the parametrics change management etc' incl 'using libraries provided by others' as necessary? Won't that updating of the groundwork suffice for similar overhaul of TF? Or is TF a whole different, old, possibly obscure/forgotten animal, modifiable only 'if the library publishers are still around and cooperating'? All the more reason then to ditch the old BricsWork/TF foundations and reverse-engineer Forms as new-type MS (parametric) solids,
which really are MS (parametric)solids while running MS;
but while running BD, in addition (optionally, alternatively) also offer a differently-expressed way of parametrically defining the same solids, and some extra modification methods.
So while running BD, any solid could be modified with equal ease, at will,
displaying either its MS-type parametric definition system and using MS-type modification tools,
or displaying its TF-type parametric definition system and using TF-type modification tools
(although many tools e.g. PushPull would work equally seamlessly with either parametric definition system).
Of course, by indiscriminate use of MS modification tools you could screw up sophisticated TF things like implied Relationships. An informative message system would be needed - 'yes you can make this move but it'll screw up that - confirm or cancel?'; 'you can modify this solid's topography but it will no longer function as a TF Form - confirm or cancel?' Across all the Verticals, such reverse-engineering of the plethora of specialised soild-types, into a common MS (parametric) solid-type, must surely be what must happen. Perhaps we'll have to wait for v9i for that full flowering of the new v9 potential.
Interesting take on why CAD dev is difficult. Reward.
'raise the tide'
Unknown said: So while running BD, any solid could be modified with equal ease, at will, displaying either its MS-type parametric definition system and using MS-type modification tools, or displaying its TF-type parametric definition system and using TF-type modification tools
